Recommendations for Red Line Radials
i bought some coker redlines a few years ago. don't drive the car much but it got to where i couldn't drive it above 55mph. worked on everything and as a last resort took the wheels and tires off to rebalance. one wheel now has 8 ounces of weight on it. better but not good. :mad: they're not very good tires for the money spent.
I had diamondback III but BFG T/A isn't enough traction now that I've rebuilt the engine.
What I have to go on it next are Avon CR6ZZ which is a DOT road race tire with a vintage tread pattern.
I sent them to Diamondback for redlines. Just waiting for new wheels to be finished....
A buddy of mine had the same issues on his 67 Coronet. He had them balanced and rebalanced multiple times. They still had a vibration on hiway speeds
He was about ready to pull them off and go with a set of RWL tires > But he sold the car instead.
Mine are the Mastercraft brand tires by Diamondback. And Ive had the car to about 85 mph with no issues
I would drive the car with the poly glass first, then decide if I didn't like them. I've back to backed cars with bias-radial and didn't find that much difference. But I just drive on decent highways and streets
Looks good Lew. What’s the tire size? What’s the wheel size?
225/70x15's. tried to put the car back as it was originally. hubcaps are original. wheel vintique repop wheels, not very good either. ordered a set of tires wednesday and going back to torque thrusts. you just can't beat a one piece wheel. the Wheel Smith is making big center steel wheels for '67 and down large hub cap cars. don't know if they're any good or not.
After 35 years with the full hub caps on the 67, I’m going to try 500s w/ black walls. Thought hard about going w the Torque Thrust and red-lines too.
i like the appearance of 500's, especially with redlines, but your back into the two piece wheel thing and the aftermarket people just don't do as good a job as OEM. of course that doesn't mean you can't end up with 4-5 good wheels. just test them for run out and straightness before mounting a tire. i ordered some ironman blackwall gr906 225/70x15's. american made, not expensive, softer tread. for something i only put a few hundred miles a year on i don't need a 50-60 thousand mile tire.
