So after switching from the drum brake master cylinder to the disc. 1966 Plymouth Belvedere Several years ago I know the brake pedal sits a little lower, and now the brake lights stay on the entire time. I know about the bracket and have adjusted this bracket multiple times over the years, my question is this something ongoing for everyone, or is it just me? I am an active-duty Marine and have had this car for several years between deployment and being stationed oversea the vehicle had its moment when it sat for long periods of time. The switch I replaced is in the following link. https://www.oreillyauto.com/detail/...+Ignition+2+Terminal+Brake+Light+Switch&pos=2 66 belvedere
Testing
Headlights function: High beams and low
Signal Lights: both front and rear work with no issues
Taillight: Illuminate with the terminal brake light switch removed but doesn't function when you press the brakes which is understandable and expected.
Once I connect power to the rear of the terminal brake switch, the same results as above which are understandable.
Once I connect a signal from the instrument panel to the terminal brake switch both taillight illuminates immediately. During this install, I haven't installed the switch into the bracket and manual pressing and released the switches to ensure it functions correctly. I know the switch works but I don't know why both taillights illuminate when I connect the signal from the instrument panel.
Wiring Harness: Painless Wiring
I consider it new but it has been installed in the car for several years also but very minimum use.
Restomod 1966 Plymouth Belvedere with a Gen III Hemi 6.1 is the reason why I chose the above harness
t
Testing
t
