Bullitt Charger R/T revisited!
Alright I found some pictures of the original Bullitt Charger R/T car that survived the movie,before,during and after being restored! These are as found and as the restoration was being started. Note the picture of the paint layers sanded back on the top of the door,that reveals the original factory Sunfire Yellow paint,then the black paint applied for the movie followed by several other layers of different colors that were applied after the movie had been filmed. Like the rings on a tree stump,this tells the cars history.
The Bullitt 68 Charger R/T during filming of the movie with the camera rig,equipment and grounding cables mounted on the car.
robs-movie-muscle-the-baddies-1968-dodge-charger-rt-from-bullitt-2022-12-10_01-30-26_959660 (1).jpg
This car has all the holes drilled all over the body for the camera rigging and holes drilled for the ground cables for the equipment.
In this photo of the car with the guy filming from the trunk you can see the ground cable attached to this hole that was drilled in the back edge of the trunk jamb.
Interior,engine,and underside pictures after being restored. Note the gunmans trench coat on the passengers seat!
Since this thread is about the Bullitt Charger,and other famous Chargers that made the Charger a legend,it's only right and proper for some exterior shots of the restored Bullitt 68 Charger R/T!
This is Mike Musto's Daytona clone known as Angrier,that was seen at the Optima Street Car Invitational. My friends did the Daytona conversion on this car.
Mike Musto's 68 Charger Mr. Angry was on the television show Bullrun.
Ted Stephen's 69 Daytona Charger that was dragged out of the junkyard and reconstructed via the miracle of AMD,on the television show Chop Cut Rebuild! My friend was involved in the project and fabricated the rear window plug for the car.
More pictures of AMD at work! My friend is installing the rear window plug,modified trunklid and wing.
The Daytona rolls from the shop on all four wheels! The last picture shows the crew that can work miracles!
A month ago I let my friends cut a huge hole in the perfectly good roof of my California Charger R/T! Before, during, and after. I let him Chop Cut and Rebuild my Charger too!
Ted Stehpen's Daytona was in really bad shape,but this Daytona known as the ravine Daytona is even worse!
Now a days this might sound creepy,but they just want to get you a loan! Lol
