WTB 1966 426 Hemi parts
Hemi2Much
3:04 PM
Alabama
Feedback: +2 / =0 / -0
After nearly 2 years I hope to be getting my engine back next week and I'm looking for a few things to make it complete.
Any help locating will be very appreciated. If you don't have anything but have a source I can purchase them from is also very appreciated.
Need ASAP:
Prestolite Distributor # 2642482 Cast iron Dual Points.
Radiator # 2582948
Fan Shroud # 2785435
(New) Champion N10Y Spark Plugs (X8)
Upper & Lower Radiator hoses (1966 Coronet 26" Radiator)
Wish List:
Exhaust Manifolds With or without Heat Risers
8 3/4 742 case center section with 3.23, 3.55, or 3.73 Sure Grip
Driveshaft for 1966 Coronet w/ 727 Hemi Auto.
Again Thanks for ANY help.
JKent
I have a reproduction right side exhaust manifold, not drilled for the heatriser, but has the plate for the heat tube.
Champion N10Y plugs have been out of production for quite some time. The superceded resistor plugs I did not find suitable. I recently discovered that N11Y's are still available and I have started using them. You might have to get them at a lawn and garden equipment supplier though. Not sure what lawnmower they fit in, but that is only one heat range hotter and I have found them to work fine for street use.
I've got a 66 hemi radiator...not pretty but restorable ...at 30lbs shipping won't be cheap. $200 for rad.PM if interested
