nodust
- 10:09 PM
- Apr 14, 2013
- red deer alberta canada
Is a 413 block out of a Dodge 600 truck of any value. I read somewhere it was the same block used in a Max Wedge.
I rebuilt the 413 in my 71 dodge C-1000. Block is ok. Crank will be 8 bolt and might also have differences. If it is a 413-3 for sure heads, intake, and everything up front is unique to an industrial engine.Is a 413 block out of a Dodge 600 truck of any value. I read somewhere it was the same block used in a Max Wedge.
Uh, exhaust notches for large Exhaust valves.... (intakes are standard 2.08).See if there is "AAQA" cast on the front of the block. This denotes higher nickel content and harder block. Used on Max Wedge and industrial, and possibly heavy duty truck. Max Wedge blocks have a machined notch at the top of the cylinder for clearance for large intake valves.
.093 over 413, you could use .030 over 426 pistons. Not common any more, but I bet more available than 413 pistons. (Just a guess).This block should have the "checkerboard ribs" on the sides of the block. what year is it?
I don't remember the thickness from sonic check, however more than one was bored .090" oversize bore.
jim
I’ll check it out tomorrow.This block should have the "checkerboard ribs" on the sides of the block. what year is it?
jim
440 Source.com Everything you've ever wanted to know about blocks and more....I was lucky and found one here in the UK.
It is the same block as the 1962 max wedge casting!
So I bought some 1962 maxie heads and then the money run out lol...
The ports are HUGE!!!
Just gotta save up for the pistons, crank, rods and intake manifolds now...
is the block casting number on the left side?
It is my understanding that RL cast into the block stands for raised large. My 361 has LS cast into it for low small, and 383's I have seen have LL for low large. The 361 is 4.125 bore and the 383 is 4.25 bore. I thought a passenger 413 which was 4.185 bore would be an RS and a 426 which was 4.25 bore would be an RL. Maybe the max wedge 413's got the thicker cylinder wall castings?I was lucky and found one here in the UK.
