64SF
I recently purchased a 69 Dart which has a 383 with 346 head castings.
A previous owner installed a Comp Cam part number 21-222-4, CRB XE262H-10 along with a set of dual valve springs (with a damper).
I wanted to install new stem seals (while I had the heads off) but found the stock seals in the FEL-PRO gasket kit will not work with the dual springs.
When I removed the spring from the valve there appeared to be a small O-ring used as a seal.
My question is....is the 0 ring the type of seal used with dual springs and is there any other type of seal that can be used.
The "bosses" where the stem seal would normally be installed do not appear to have any machine work done.
Any thoughts, comments or suggestions will be greatly appreciated. Thanks
