- 10:19 AM
- Apr 13, 2012
- Granite Bay CA
There are strong arguments on both sides. I'd like to hear yours.
I have always used ported vacuum. To me, it made sense to let the engine operate with simple initial/base timing at idle, let the distributor operate on it's own in regards to mechanical advance and then let the vacuum can add timing at cruise to burn the fuel more completely at cruise.
I base my habits here on what the factory did.
Am I wrong?
I could be. Nothing is original in the engine anymore except that the block is still cast iron. Everything else has been changed so maybe I need to change my thoughts on this subject. I have more compression, a bigger cam, a bigger carburetor and a bigger exhaust system.
I used to scoff at guys like "Don" at FBO ignition for his preference to run manifold vacuum. It seemed odd to me that you'd load the engine with initial and vacuum timing to some huge number around 30 degrees, then once you crack the throttle, the vacuum drops like a rock and you lose half your timing.
I'd love some explanations as to which you prefer and why.
Am I wrong?
