For comparison. The inside of an Indy 440-25 crossram. Even though mine has the carbs in the center.
Doug, you are pushing all of my intake obsession buttons.For comparison. The inside of an Indy 440-25 crossram.
Quick question. How do you think this type of manifold would compare to a normal upright tunnel ram? The roof of the runners has a sharp 180 to do, if it is to share plenum volume with both sides. While this one seems to have a generous plenum I wonder how the intake pulse is affected by the sharp turns. That modified one is some legit work on manifold air management.For comparison. The inside of an Indy 440-25 crossram. Even though mine has the carbs in the center.
I know a few guys who swapped the 440-25 using 750 Eddy carbs for the indy -3 single plane and a dominator. The results were very similar. The pictured below mods have been tried. But all the combos using them were slower than mine. The bottom view of the plate shown is very similar to the Indy carb plate. My friend Casey runs a Bischoff 588, B-1 originals, Indy tunnel ram adapted to B-1 heads in a 65 Coronet, Mine is DVW garage built 580", -1's with the crossram. We both run N/SS.Quick question. How do you think this type of manifold would compare to a normal upright tunnel ram? The roof of the runners has a sharp 180 to do, if it is to share plenum volume with both sides. While this one seems to have a generous plenum I wonder how the intake pulse is affected by the sharp turns. That modified one is some legit work on manifold air management.
—-I know a few guys who swapped the 440-25 using 750 Eddy carbs for the indy -3 single plane and a dominator. The results were very similar. The pictured below mods have been tried. But all the combos using them were slower than mine. The bottom view of the plate shown is very similar to the Indy carb plate. My friend Casey runs a Bischoff 588, B-1 originals, Indy tunnel ram adapted to B-1 heads in a 65 Coronet, Mine is DVW garage built 580", -1's with the crossram. We both run N/SS.
He's about .10 quicker and slightly heavier.
You misunderstood. Mine is stock. The modified ones pictured are fair amount slower.—-
Wow look at that workmanship inside that intake. A guy can see why it works so well. Mine had the stuffers inside like the ones in another picture you posted. When I switched from the 440-25 to the Super Victor with the 1050 Dominator my ET went from 10.45 to 10.38. My 440-25 sure didn’t compare to yours though. Amazing work!
Unless the "eye candy" effect is a factor. For me, that's part of it, but I want to "honor" the "V-code" aspect of my Roadrunner, thus my decision to try 3x2 of "something" as long as possible.Awesome work. Your answer shows that it’s hard to beat a good modern single plane with a set up 4bbl. Thanks for sharing.
I live on Social Security. If I need race parts, I do side jobs. Doing two transmissions right now. A 68 Belvedere 318 to 440 swap coming in two weeks. That'll buy new slicks, brake pads, and a 55 gallon drum of 114. And have cash left over. I'm ready to hit the track at 68 years young. Enjoy life.If I was still a working man and had my shop then I think a 3x2 or a Xram would be that kind of shiny bauble I would love to try. But alas I sold my tools and house. I’m now a gentleman of leisure on a fixed income. So I’m reliving my youth through you guys. I’m just happy be able to talk to motorheads and look at projects. Keeps me excited about the 63.
I wish I could do that. But I am 100% disabled. Lungs heart and back but I get done what I can. Just takes longer. I’m just glad I have my dodge and at 75 I’m still having fun and watching Lemon Wedge build his beast. I was 60 when the agent Orange hit me. Now the Camp Le Jeune water is acting up with Parkinsons. But I’m happy. This is a great forum and awesome People.I live on Social Security. If I need race parts, I do side jobs. Doing two transmissions right now. A 68 Belvedere 318 to 440 swap coming in two weeks. That'll buy new slicks, brake pads, and a 55 gallon drum of 114. And have cash left over. I'm ready to hit the track at 68 years young. Enjoy life.
You need -.010" bearings since the crank is .010" undersize already. It's ground on the high side of tolerance (spec is 2.6145"-2.6155" at .010" undersize). No one makes a .011" under bearing for this motor. The P bearing is a passenger car bearing. The Clevite MS876P is an H series bearing which is a performance bearing. My Bore size dimensions are correct. Passenger car bearing clearance is generally tighter. I've had no clearance issues useing th H series with proper line bore and crank dimension. If your crank was in the middle of tolerance you would have .0028", or at the minimum of the tollerance you would have .0033" My bet is the line hone isn't tight.“MS” is a series similar to “P”? I’ll go looking for those.
King makes a set of “-.001” bearings. in Theory that would get me to .0024, but I realize I’d have to install and measure to verify that. Another $100-…….
CHRYSLER King Engine Bearings MB555HP001 King HP-Series Main Bearings | Summit Racing
Didn’t get around to measuring the bores tonight. I’ll get out there tomorrow.
