I have so many of these. I've tried to block them out but some you just cannot forget:
...So the front brakes were not working and your solution was to clamp off the rubber brake hoses?
...The K member interfered with the oil pan of your engine swap so you thought it was a good idea to torch half of it off?
...You put a mustang II floor shifter in for what reason?
...The exhaust manifold was leaking so your fix was to take it off and park the car in a field for 20 years?
...Did you ever jack this car up on something other than the rocker panel?
...How could you have possibly forgotten to remove the sheet of tin foil in the valley when you changed the intake manifold?
I could go on and on.
