John H
I recently purchased this car and have the following ?'s.
1. I can not get power to my trunk light. I have traced the wire to the harness behind my rear seat where it ties into. I have tested the bulb and the wire with a test light.
2. I am trying to put the bulb into my BRAKE light indicator on the dash but can not get my fingers under the dash to install it. Does the indicator pop out of the dash so I can re-install the bulb and holder? Also, the light does not illuminate when the emergency brake is engaged. I tested the bulb and it is good.
3. When driving the car the alternator gauge indicates charging (to the right). I just installed a new battery because the car's old battery was 10 years old. It starts fine with what appears to be plenty of juice. When it is at idle, the charge gauge is in the middle. Headlights are bright. The faster I drive, the more it indicates charging. When I turn on the heater and headlights it also indicates charging.
4. The AM radio is not giving me a signal. You can hear it turn on through the speaker (cracking noise) and the antenna is plugged into the radio. How do I get to the antenna in the fender if I had to change it out. It's manual operated. Not sure If they had power antennas back in the day.
Thnak you everyone.
Thnak you everyone.
