Need torque converter weights for 73 440 cast crank engine. Anyone know the specs?
Nismobishi
10:38 PM
Fresno, CA.
Hello,
I have a neutral balance tc on my cast crank 73 motor home 440. I do have the weighted harmonic balancer but I still have a little vibration. I need to weld the weights on my tc. I don't want to get the new compensated flex plate because I don't want to pull out the trans, I want to weld the weights on through the inspection cover.
I have called Mancini and 440 source and nobody sells them anymore and nobody knows what they should weigh. If I knew what they should weight I could probably cut some out of bar stock steel.
Did the info from TCI in your other thread not work out??
I think there's some info in the chassis of motor bible (Mother Mopar).... I'll have and look and report back here a little later.
Well,
I saw the torque converters that they sell and I saw where I need to weld the weights but I couldn't figure out which weights I needed. I called but they were super busy. I will call back tomorrow.
Sorry for the new thread here. I had new questions and I couldn't edit the title of the old thread to reflect that.
Fixed that....
So..... the Mopar kit including instructions from Mopar Perf was # P4120241. IF it exists from any supplier, I do not know.... still hunting for further info.
still hunting
69Bee has provided the info you seek, in this thread.... look for the pix of the Chassis Bible...
[/URL][/URL][/URL]
I was reading through that thread and I see info about the 6 pack converter weights but I am under the impression that the 74 and up cast crank used heavier weights than the 6 pack used in 70-72.
I found this. It looks more correct I believe but I just don't know for sure.
Torque Converter Balance Weight, Chrysler 10-3/4" Non-LU, TF-6 A-904/TF-8 A-727 | eBay
The cast iron is not as dense as the forged steel. That is the reason for the external weights, and why they are bigger. The 6 pack rod engines have the weight in a completely different spot, like opposite the cast crank weight.
I have a 73 340 I have had since the 80's. As you know the 72-73 340 have a cast crank with it's own weight balance. In the last 30 some years I have had 3 builders balance it and each said the previous one screwed it up and they got it right. They never did. Always had a slight vibration at 2500 plus. Could never find that specific flywheel either. I bought a flywheel from this seller about 3 years ago and it is perfect, smooth as silk. It is such a pleasure to drive now.
Bolt on Flywheel Weight 130t for External Balance Cast 400 440 Mopar Dodge A833 | eBay
I know yours is an automatic but maybe they could tell you the weight for balance and they do have a location on a flywheel so possibly you could transfer that to a convertor? Just an idea.
Sorry, I thought the info was right there, but I see now it was'nt....
So, 6.50 in.-oz. of unbalance added to flywheel for 440-6bbl. You would need 12.90 in.-oz for the 440 cast crank.
HTH, Lefty71
So 12.9in.-oz is for sure the weight for a cast crank 73 440? Next question, what the heck is in.-oz? All the weights I see are in grams.
Thats quite exactly what the book says, sans the 1973 part.
I can't answer for exact weight of what's in the kit, nor their exact placement.
BTW, if no suppliers have the kit new, I did see recent completed sales on the Ebay, or bm02tj's idea is golden, if you can find the right one.
in-oz is balancing terminology (Weight in oz)x(inches from centerline) for a object rotating.
So you can convert to grams easy enough 1 ounce is 28.35 grams. Your balance weight will be lighter the farther it is from the centerline. I think a 440 cast crank convertor used two different weights over the years but they were the same balance: 77 and up used a heavier weight and closer to crank centerline; the other used the lighter weights but farther from crank centerline. I think 11 and 12 in the below quote are convertor diameter? The 12.9 in-oz is the overall balance and since the weight size is dependant how far it is from the crank centerline. Using the 12.9 in-oz should equate to 6.09" out for the 60 gram weights, 3.657" out for the later 100g weight.
Below are weight sizes for the stock convertors:
28.35 oz equals 803.709 grams
a gram is smaller than an OZ
I have a 77 MH 440 & 727 trans. If it'd help I can snap a pic of the weights on my converter. I'd think you could easily find a MH 727 converter cheep enough ina junkyard to rob the weights from.
