I don't even jump off of a step, little less a few hundred feet, no thanks!!I don't know. I am a big guy, and by experience, I have found that there is a LOT of gravity that follows me around.
Don’t worry about a bungee cord snapping if you ever go bungee jumping. Thankfully it would take hundreds of snapping cords to break your rope and lead to a dangerous fall.
Around here, they don't waste time separating the cars, they are dumped one after each other. One end of the car has a conventional coupler, the other end has a rotating coupler so the cars can spin without binding. Obviously, the train consist has to be put together with the proper couplers in the right order, which is why those coal cars usually have one end painted to indicate which is which.Once they are detached from the rest of the train, freight cars are then rotated by this piece of machinery to remove the coal inside of them, so the resource is never actually unloaded by human hands.
Reporters out on the field always look so fabulous, but no one really shows you what’s going on behind the scenes, or in this case, their backs. In reality, journalists have to wear transmitters, cables, and clip-on microphones that make them look like cyborgs.
After me, you mean!!!! LOLI wouldn’t mind the job of wiring her up.
A few days later after a good hosing?
Yep, but I found that 0.050" would be better on the vent glass.Same stuff used for the vent window?
