SOLD 67 Charger L Code 4spd Dana Project $7000
mopar6970
11:24 PM
Va.
Feedback: +1 / =0 / -0
1967 L code Charger. Factory 440 4 speed Dana 60 car. One of 132 440 4spd cars built. Original owner pulled the engine out in the early 80s for a rebuild and car was never put back together. I have the block, crank, dual snorkel air cleaner, exhaust manifolds and radiator shroud. * heads, intake, carb, distributor, radiator are missing. I have the 4 speed, Inland shifter, bellhousing, Z bar, flywheel and driveshaft. Dana 60 has 3:54 gears. Black Interior is complete and has the famous “RECALLED“ 3 spoke steering wheel.. Car has solid frame rails. Needs full interior floors. Trunk will need a small patch in spare tire well. Quarters are decent with some rust behind the PS wheel well……DS has a crease and a dent. Doors are starting to show rust along the bottom. Fenders have some lower rust. Hood and trunk lid are junk…I have a good hood. Vent fins in the cowl are rusty and pitted but I have nice cowl panel to go with it. Car has fender tag and probably a build sheet as the interior has never been pulled out. The original title was lost in a house fire but the new title is on the way. (April 5). This is a very good project and a rare one at that. $7000.00 I will be adding more pictures, So if there is something you want to see
let me know. Not interested in trades. PM me for a contact # for ?s……Serious inquiries only please. Thanks for the ad!
The block was bored .010 over I think but you can’t buy .010 pistons that I know of. Rods and pistons were MIA. I never checked crank journals. Everything was covered with bearing grease so there should little to no corrosion.
Dropped it down to $7000.......Hoping someone will save it.
Is all the linkage and mount for the shifter there?
Man I wish you were closer.
Yes linkage is still on the trans......if you blow up the pix you'll see it.
Here's the fender tag....
Now has Clear Va. Title……….
** 67 Charger 440 4spd - 1 of 132 produced / 18 known to exist to date **
I guess nobody wants to save it and Im tired of messing with it, so its getting parted.
67 Charger L code 4spd body rolling w/8.75 rear and clear Va. title. Asking $3000
67 440HP block w/crank (10/24/66 casting date //// 12/6 assembly date Asking $1500
67 18 Spline 4spd swap; Steering column (no wheel), Pedals w/push rod, 11" flywheel, 11" Bell housing w/fork, Z bar w/fork rod, 18 spline trans, Inland console shifter linkage Asking $3500
67 Dana 60 w/ 3:54 gears complete drum to drum. Asking $3500
