Big Bad Dad
- 12:40 PM
- Jun 11, 2011
- Fincastle, Va.
Yes, I did a search, but most of the brake fluid threads are old. I'm going thru the brakes on my 67 R/T. I just took everything apart, and while there is less than 10K miles on it since I did the brakes before, it has also been over 25 years. There has been some condensation in wheel cylinders. I plan to replace all wheel cylinders and rubber hoses. The master cylinder was replaced about 12 years ago, so I have not decided on it yet. May pull it apart and take a look. Anyway, what do you guys think is the best brake fluid to use now? My cars mostly sit a lot, but I am hoping to drive them more now that I am retired and have time.
I have always used DOT 3, but wonder if one of the newer fluids would work better for me as far as not having moisture problems.
edit: This is the original 11" manual drum brakes.
