Distance from Cowl to center of air cleaner on 68-70 b body
TexasRoadRunner68
3:37 AM
Dallas,Texas
Can someone measure the distance from the cowl to the center of the air cleaner on your car?
It’s for a custom hood for a 70 4 speed charger. I can’t do it myself since the engines out of the car.
I would assume this is pretty much the same on any 68-70 big block b body right?
I got 12.5 inches from nearest point on cowl to the center of filter on a 383 engine with stock manifold. Hope this helps you.
Here you go. This with a 440/495 single 4 barrel Demon 850 on an Edelbrock RPM intake.
Good luck.
Note it's not on the centerline of the car as well.
