Huicho417
- 11:07 AM
- Sep 15, 2020
- San Antonio , Texas
I just finished replacing the oil gasket and pan. Before that the rear main seal. This is the third time I replace the pan and gasket and it leaked again. No leak with just the car idling, but once I get it over 2000 rpm it leaks. I am using the Milodon 4 piece gasket with a summit racing pan. The leak only happens at the rear and looks like it’s from the rubber seal. Not sure that this pan is fitting properly. I am going to clean my original pan and see if that is the issue.
Is the rear main seal placed correctly on the images attached. The main cap also seems to sit proud of the engine block. I removed it to see if I could push it back but it only goes in that way when I tighten the bolts. Not sure if this is an issue.
Also, are the ears that stick out past the cap supposed to be cut?
