Charlie Brown
- 3:26 AM
- May 23, 2021
- Vars, Ontario, Canada
I have an Edlebrock 1405 600 cfm carb with auto choke. Fast idle works as it should. Issue - when engine is cold and I'm in cruise mode, the engine is surging. At operating temperature, it runs perfect. Carb currently has .98 jets in primary circuit and metering rods 1446 ( .068 x .042). Phoned Edlebrock, but that was a waste of time. Waited 45 minutes for a tech and then he told me to move the position of the accelerator pump lever - this issue is not under load but in a cruise situation when cold. Would increasing the primary jets to next size up (.100) help? Or should I be adjusting something on the electric choke? Thanks, Charlie
