O ring for power steering pump reservoir
67500383
8:53 AM
I.E. California
Hello everyone! I am trying to locate the correct O ring for my Power steering pump reservoir that is leaking.fluid. I have bought 2 different power steering rebuild kits online those were wrong and no parts store around here I went to has the correct large O ring in the kit that seals the pump to the reservoir. My power steering pump is the TRW "large notch"
Does anyone knowthe correct O ring that is required and where to get it? Thank you
I eliminated the o-ring completely and filled the groove with plenty of ultra black rtv. Reassembled and trimmed excess with a blade once it fully cured, repainted it and hasn't leaked in 4 years.
I was able to find the O ring that's needed for this pump at a huge O ring store about 20 miles from me called "O rings and things" in the city of Fontana Calif. I bought 2 in case another is ever needed. It's sealing perfectly
Glad you got what you needed!
That's what I did years ago as well. Local hydraulic/O-ring supply place sold me a bag of 20 or so of the ones I needed for like $10 (and only because they had a $10 minimum!)
Sometimes I think folks get caught up in the "I probably need to get this from a Mopar/Hotrod shop/performace auto type place" when if you look around your area, you can sometimes find the same or better from Joe Blow's industrial supply...
i had a very hard time finding the O-ring that i needed and O - RINGS and things had what i needed 69 cents
i had to same problem when trying to find the big O-RING for my 64 Plymouth Fury luckily i had the old one with a micrometer i measured inner and outer diameter and thickness and the place in California has them 69 cents with shipping about $13.00 i would RECOMMEND them to EVERYONE !!
