I use mine the most to get broken bolts out. Once you master that you're a local super- hero lol. Sadly.
I have a Lincoln Magnum 250. I bought it in the late 90’s, it has been a great welder.
Thanks, but no. It's me. My daughter's welds are great.maybe it's just the cheap welder....... if you're using flux core, that won't help either
Brand names are important. By from who can provide service, repair, and consumables.Lincoln is a big name brand out here also.![]()
This ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^Since no one has really mentioned wire size I'll touch on that. I have a really nice Miller 180 220V MIG that I run .030" wire in with 75% Argon 25% CO2 mix gas. It's a fabulous welder, but as previously mentioned it's really hard to weld really thin steel metal (body panels with), so I bought a Miller 140 110V that I run .023" wire through for thinner jobs, also using 75% Argon 25% CO2 mix gas with it. The welder you decide to buy is totally dependant on the jobs you think you'll be into the most. If all you plan to work on are thinner metals then a 130-140 amp, 110V machine with thin .023" wire is the best option. If you intend to weld 1/4" all the time get a 220V machine and use .030" wire.
Tom
Well you guys don't make welders we do. So pick one .220 or 240.Whichever one I buy it will be 230 Volt supplied. That's just how we roll down under.
Thanks for all the great input here.![]()
