chargervert
That car should be called LSD,insread of GTX because whoever did that to that car obviously used a lot of LSD!
In the 70’s I don’t remember that kind of customization, I would have laughed at it then, I laugh at it today.
Unbelievable
The old original "Rock Crusher" was a "close ratio trans, the same as the M21. The new wide ratio, similar to the M20, ratio wise.
Both version will have similar RPM drops between 1st, 2nd and 2nd, 3rd, but the wide ratio will have a bigger drop between 3rd, 4th, hence the wide ratio name.The, wide, also features lower overall ratios in 1st, 2nd and 3rd gears, helping to compensate for higher, freeway friendly gears, and still provide a nice hole shot, but allowing that road friendly gear to be utilized in 4th gear.
Had a wide ratio T-10 in my 66 BastFack Mudstain with a 2V 289 (with a 4 barrel,Torker and headers on it) and it got off the line pretty good even with the 2.80 gears and imo, was ok for street racing since 4th gear rarely came into play because by then, it had already ran a 1/4 mile and was really going too fast for being in any of the populated areas anyways. Kinda surprised me that it ran a 15 flat at the track...The old original "Rock Crusher" was a "close ratio trans, the same as the M21. The new wide ratio, similar to the M20, ratio wise.
Learn something new nearly every day! lolAnd rock crushers were noisy hence the name, but everyone knows that.
The 1957 chevy tri five, was no supposed to come out that year with the fuel injection. A friend of mine that I met when I was building advertising displays, was a car designer fresh out of school in 1959 and was the designer of the wings on both the 59 and 60 chevy. He told me the their spies overheard something about Ford coming out with fuel injection for 57. It turned out to be air injection or some sort of air intake, ram air. I don't remember and I know nothing about ford's. It was pulled and reintroduced. It was a mistake, that I know.1957 Chev 283 h.p. 283, with fuel injection. 1957 DeSoto. 345 h.p. 345 Hemi. Both with 1 h.p. per cubic inch.
There was a time.....but not now.
