magnetb0y
Hi,
I'm in the middle of a complete front end rebuild including drum to disc front conversion with power booster.
I bought a kit from pirate and so far no issues. I'm at a point where I can either convert my old brake line system or redo more.
The kit from Pirate came with an adjustable proportioning valve with instructions to place between the back brake line and the stock metering valve.
I've got the back line off the valve, but boy that took a while. I'm now debating putting in the adjustable proportioning valve or replacing the metering valve entirely.
and re-piping all the front lines and just chaining in the back (till I deal with the rear axel in the future).
Does anyone have any experience reusing the drum lines with a adjustable proportioning valve for the rear circuit?
If I did that can I just bend the old lines to the master cylinder and make them work as well or should they be re-piped?
Should I just buy an new all-in-one combo metering/proportioning valve and redo the entire front circuit and piece in the back?
Any help appreciated! Thanks!
My metering valve and adj prop valve
Adj prop came with kit
All in one that I would have to buy
