Cudatali
Hello, I am working with a 4150 style Quick Fuel 680 on an engine with a healthy cam, which I have jetted and tuned. Primary and secondary throttle openings are at a minimum and idles at 900. I didn't need to drill out the butterflies. 4 corner idle screws are 1-1/16 out. All my other A/F ratios are on the money and the car is very responsive. The engine seems happy with a idle mix of 13.4-13.8 AFR in park (8 in. vacuum) but it goes to 15.0+AFR when in gear (5 in. vacuum). Obviously a large drop in RPM and the engine doesn't sound happy when it goes that lean. Initial timing is at 23. The car starts right up.
I'm thinking it's the low vacuum signal once in gear which starves the engine of fuel.
Any other ideas of what it could be? Or if I am on the right path, how do I overcome that?
Thanks!
Thanks!
