tonyp25
So after reading a bunch of posts here I wanted to try my hand with a digital timing light (also has tachometer built in). The engine is running pretty smoothly but wanted to see what you all thought. Would love any input.
At idle (after it’s warmed up) my RPMs were roughly 730 and drops about 100 when put into drive. The timing was at 15 degrees. At around 2500rpm the timing is at 34-36 degrees. This is all with vacuum advance disconnected.
If it helps it’s a 318, automatic, 4bbl Carter, 340 edlebrock manifold and Comp Cam. Running non-ethanol gas. I found the Cam receipt but the numbers don’t mean much to me (if anyone could give me more info, I’ve attached a picture of it). Not sure if it matters but it also has headers and flowmaster mufflers.
