- 7:51 PM
- Dec 4, 2009
- Pasadena, Texas
Bout to jump in my redneck pool!!
Damn.Bout to jump in my redneck pool!!
Thought it was getting where it felt hotter then looked at my gauge! At least the humidity is only 33%Damn.
Didn't go to very many swap meets in the middle of the summer time around here.....just too dang hot and back then, I could stand it better.Was at carlisle for a while earlier today and it was too hot. We left about 1. The feel like temp was 109 at that time with the humidity. The ac at the fairgrounds diner(next door)wasn't working very well either
Did you fill the bed of the Dakota with water again?Bout to jump in my redneck pool!!
Make sure the tailgate is locked this time....
Nope.....I have a 100 gallon watering trough.
Looks like your camera is suffering from the humidity also.I certainly had to get used to the humidity here. Commiefornia is dry heat, this is wet heat and I’ve had to put 2 more holes in my belt cause I’m sweating like a whore in church all day! After I’m done with the fence, carport is going up in front of my shop and then getting a mini split ac system for the shop, gonna use 2 inch rigid foam for insulation. I’m tired of it being 110-115 in there all day!
And where exactly are you in Texas again? lol. 51% here now up from 32 for a low and I'm 9 miles from Galveston Bay lol Maybe you need a redneck pool too!I certainly had to get used to the humidity here. Commiefornia is dry heat, this is wet heat and I’ve had to put 2 more holes in my belt cause I’m sweating like a whore in church all day! After I’m done with the fence, carport is going up in front of my shop and then getting a mini split ac system for the shop, gonna use 2 inch rigid foam for insulation. I’m tired of it being 110-115 in there all day!
