dvw
So the story starts last Wednesday when the motor is back at 1am. New thicker .187" Diameter piston pins. The crank has been polished and rebalanced. The trans issue was due to the valve body. It had a crack in it. Now it had been swapped for a Turbo Action RMVB. We started in my sons garage Thursday at 11.00 am to install everything. Primed it on the stand. Installtion comes to a halt. The converter wouldn't slip in. Pump was jammed. Pull the pump. Turned out to be a small piece of aluminum shaving on the pump gear. He had helicoiled a few holes. With that done, in it went. Then we noticed a drip coming from the external oil line fitting. Drained the pan. Came up with a fix. Now the nylon AN washer has disappeared. After 30 minutes looking we gave up and had lunch. Came back out and found it 8 feet from the bench. The last hickup, or so we thought was a missing MSD coil nut. Yes it's some oddball fine thread metric. Run to the hardware store. It's now about 7:30. Engine fires right up but runs poorly. I check the header tubes. All 4 front tubes are cold. Restart it and I can hear a whistle sound. Last hickup. When I installed the spacer and lid on the Mod Man intake I slipped the fuel regulator bracket under the front carb instead of on top, dah. Anyway refire it set the timing and idle. Runs decent. The metering rods in the AFB's are dancing due to the incorrect springs. It's decided we leave it for now as it left good on it's only pass. It's loaded in the trailer, and truck fueled about 12:00 am. It's now Friday at 7:00 am and we're both going to race at the N/SS Bash series in Columbus 4.5 hrs away with the car totally untested. First TT is at noon. I leave on time. My son's 1/2 late. On the way down he gets into a freeway closed situation due to a wreck. His trip ends up being 5 1/2 hours. We get to Columbus and racing has been cancelled due to rain. So we set up for Saturday. The cars 1st full pass is a 9.89@134. We slow it up to 10.0 index. My son is an amputee and hasn't foot braked for close to 20 years. Though rusty at the tree he goes some rounds. The car is pretty good. We both ran 2 events on Saturday. Vacuum pump canister needs some better baffling. It spun the tires on 2 passes. Next it'll get shock, timing, jetting, shift point s all tested. Is there more in tit? Or is it perfect already? Time will tell. For sure the air quality wasn't ideal. My grand daughter crewed for us. Sundays event was cancelled after 1st rd due to weather. All in all it was a good outing.
DougMan Indy intake?
