What throttle linkage?
unclepunchy
2:18 AM
Victoria, BC Canada
Hi Folks,
I have a 73 Duster, 4 speed I just slammed a 383 in. All I have is the throttle cable poking out the firewall. I need to know what bracketry/kit I would need to purchase?
Running a stock 4bbl manifold and a Edelbrock AVS, 650 CFM. Cheers.
Hi Folks,
WHY not use the origional carb (Carter AVS) that came with the engine origionally .. ..then everything fits and functions as b4?.....from the choke to the throttle cable and kick down linkage.....just a thought......
BOB RENTON
Every manifold change I do on my A body BB takes a different bracket. I start with an original cable clamp/hold down and make my own. Function over form, I guess.
You'll need a throttle cable bracket, the stud and Edelbrock adapter that turbine68rt linked to, a throttle return spring and a return spring bracket if you don't already have one. This is set up for a 727 so it has KD linkage, but the rest of it is more or less the same.
