fullmetaljacket
- 12:38 AM
- Oct 15, 2010
- Brooklyn, New York
Another hidden shred of weight loss ideas sits right there smack in front of your face. It can't get any easier than these made out of simple flat stock aluminum with three bolt holes drilled out. What are they? Lifter valley tray bars. The steel stock pieces like the ones below stand in as perfect templates and weigh 3/4 of a pound total. The aluminum replicas are at 1/4 Lb.While region #1 is coming to a conclusion unless there's an elusion to other tricks, a big block fuel pump can weigh as much as 3-1/2 Lbs with push rod and all at the very front of the car. All this can be switched to the rear of the car with the use of an external electric fuel pump or in-tank unit. Not necessarily removing the weight, but repositioning it for more effective weight distribution.
My fuel pump weighed 3 Lbs with push rod. Electric in tank unit weighs a little more, but placed in the right place.
Shaves 1/2 Lb right there. That's 8 ounces right there towards the goal of 1600 for a total of 100 pounds shaved.
Let's not forget the 6ix mounting bolts in aluminum.
All in all, this practice extends the joy of the hobby/sport/emotional rescue a bit longer.
