haywire 440
Full Speed Ahead
As shown in the picture the valve and all the parts are gone. Is tapping threads for plugs a good solution?
Did you tap the brass sleeves or remove them and tap the metal?I used allen plugs 24 years ago and still holding up fine.
I know those are hard to come by now a days. I thought a little bit about it but don’t think their needed.complete rebuild/replace kits are available. Prices are from: Okay!... to Really?
I’m going the tapping route.
Thanks again!
I am about to replace short headers already on my 72 Charger with stock exh manifolds. Only thing is the heat valve is OK in my replacement one but it’s external spring and attachments are toast. What do replacement parts cost and where can it be sourced? Preferably in Canada. What is the sacrifice if I just weld the valve open or remove it and plug the holes?I know those are hard to come by now a days. I thought a little bit about it but don’t think their needed.
They charge in Can$. I have dealt with them since at least 1989 very reputable.Here’s a company in Canada that sells the complete kit. I don’t know if individual parts are available but search Classic Industries, Mega Parts or Google.
National Mo-Parts – Est. 1987
Any daily drivers with cool temperatures need them. We don’t have one on our 85 Ram B350 360. Even at 70F it needs to warm up after a cold start. If it sticks closed, you can choke the engine.I've seen those things stuck closed before and that's not good. Also seen them where the flap came loose and got stuck down in the pipe half closed. Plus they can rattle as they age. I always took them out on my cars and trucks
