Wietse
What settings do you have for the AFR? (Idle, Cruise and WOT)Update: I've got the car running and driving but having an issue dialing in on the proper timing to alleviate it running rich and pinging in the pipes.
440.
Edelbrock RPM Performer Heads
CompCams Xtreme Energy 224/230 Hydraulic Flat Cam
Holley Sniper Dual Quad Sniper
Holley Hyperspark Kit (distributor, ignition box, ignition coil)
Powermaster Onewire Alternator 165 amp 8-58529
I'm soooooooo close but just can't quite find the sweet spot on the distributor.
I have initial timing at 15degrees as most people have requested but its still running lean.
Initial timing you set for 15 deg, what about the WOT timing?
I assume you followed the correct procedure for clocking the distributor with the plastic cap right?
Not sure if you already used the laptop to configure a timing table yourself? Or are you just using the handheld of the Sniper kit?
