1967 Dodge Charger Ground Wire & Interior Chrome
Charger Too
1:50 AM
Illinois
1967 Dodge Charger: Question 1: 383 Engine - Does the ground wire go on the right side far back intake manifold bolt or in the hole on the far back right side head? I would need to get a bolt if it goes in that hole. Question 2: I need the chrome trim that surrounds three sides of the hinge plywood that is in back of the rear seats. Does any vendor reproduce that part or does anyone have a good used one? Thanks!
Do you have a pic of the trim pieces Around the hinge that you need I might have it if your not looking for brand spanking new
I believe the ground wire attaches to the rear of the right side head.
Please start a parts wanted thread for your trim piece.
On my 66, front ground lug from battery is under bolt that holds the Z bracket for the springs for tranny linkage.
Rear gnd is a bolt at rear of the block to firewall.
I don't have any pictures. It is two pieces of thin chrome, L shape that goes on each side of the plywood board (covered with carpet) that his hinged on the bottom, in back of the rear seats.
I thought I had extras but I only have a complete seat minus the cardboard and carpet. Sorry
You are talking about the divider that opens up to the trunk? Have not seen any vendor that sells these. I might know were to locate a set. How soon do you need?
Within the next few weeks. Thanks!
Well, IF I get to a farm that is a couple hours away, I will pull the best set (if there is one) off the one of the parts cars. I need to go there and get some parts for my car. Missing a front seat of hinge bolt washers.
Just a mention for originality Ma Mopar painted the Battery ground cable, engine color, partially up from the grounding bolt about 1/4 out up the Ground Wire going to the battery. Just a pass at the bottom of the wire with the engine color.
