Yes the 1970 discs work fine as 1 wild Rt says.
I used a manual disc master from a 1973 Charger. Works great, I never measured the bore size.
I am pretty good with a flaring tool, so I bent up my own lines. This is not for everyone, though.sounds like a line kit and a proportioning valve for a 70 would be in order?
Like I've stated before, you'd think what worked on one conversion will work on another.... But that's not always the case... Back in the 70's &80's I added discs to many cars & never had an issue.... These days that doesn't seem to be the case for lots of guys.... I don't know if it's parts issues, if proportioning valves are gummed up & not wanting to play nice... I know some of the repo valves flat out don't work, the spool binds in it's bore...wait....... wut?![]()
Drum Booster or Disc Booster? Cause the Disc booster puts out about 50% more boost,I have my original booster and prop valve for my 68, I assume I'll be having the booster rebuilt and clean up the valve (for my car, not the 67)......I'll trust that over chinesium
Depending on condition IMO around $300... Hubs? Or rotors? Cause new OE style two piece rotors are $$$ if you can even find them... New unicast rotors are $60 ea which is what I would do...so........ what would be a fair "friend to friend" price for the E body spindles, hubs, caliper cores , ect.?
Depending on condition IMO around $300... Hubs? Or rotors? Cause OE rotors are $$$ New unicast rotors are $60 ea which is what I would do...
