They look good but don't work all that well.
That’s an understatement if there ever was one. I find that the right side mirrors on my Chargers are completely useless.
Might try one of those convex spot mirror addons. Put some looped tape on the back side to see if you think you like it before pulling the backing off because once you stick it on, it isn't real easy to get off. I do that to all of my vehicles now and have been doing that for over 30 years now and not a soul has said anything to me about using them.That’s an understatement if there ever was one. I find that the right side mirrors on my Chargers are completely useless.
Might try one of those convex spot mirror addons. Put some looped tape on the back side to see if you think you like it before pulling the backing off because one you stick them on, they aren't real easy to get off. I do that to all of my vehicles now and have been doing that for over 30 years now and not a soul has said anything to me about using them.
Plus when you get older, turning the head 360* isn't as easy as it used to be.....I disagree about "completely useless".
You do have to aim it directly at your blind spot, which means you don't see any of your car.
That can be a bit disconcerting at first.
...but glancing over and seeing a big grille in it when you can't see anything in the somewhat large C pillar view block on our cars can be a life saver.
That would have been cool to see! I can barely get past 90!Plus when you get older, turning the head 360* isn't as easy as it used to be.....
Just ask Linda Blair.Plus when you get older, turning the head 360* isn't as easy as it used to be.....
Was that your right or my right?That’s an understatement if there ever was one. I find that the right side mirrors on my Chargers are completely useless.
I know a guy who got both arms cut off and once they were reattached, they were on opposite sides of his body....his right became the left and vice versa but he still had a right and left eye where they belonged. At least he still could see right...Was that your right or my right?
That’s what I’m talking bout!I know a guy who got both arms cut off and once they were reattached, they were on opposite sides of his body....his right became the left and vice versa but he still had a right and left eye where they belonged. At least he still could see right...
Ok not a flat spot but it’s dimpled from the press as a secondary operation at the stamping plant. You can see clearly what I am referring to.I don't think there should be a "flat spot".
I have seen people torque the large nut down so much that the metal distorts, though.
I'm not sure that's a factory 'dimple'......Ok not a flat spot but it’s dimpled from the press as a secondary operation at the stamping plant. You can see clearly what I am referring to.
Been a long time since pulling off a right (right?) side mirror but don't recall seeing sheet metal that bad....although one was close.I wasn't gonna say it since I brought it up in the first place, but I agree.
It's real easy to over tighten the mounting hardware and cause that, although that's one of the worst ones I've ever seen.
Usually it's just the large stud/nut.
