 - 7:42 AM
 - Apr 13, 2012
 - Granite Bay CA
In my ongoing quest to get the brakes to feel right in my red car:
I have tried a multitude of combinations. Factory Cordoba 12” front disc/ rear drum with a 75 Dart power booster, 11.7” rear discs from Dr Diff, manual master cylinders with the 4 wheel disc, back to the Dart booster but with bigger front rotors with smaller calipers, another manual MC, hydroboost, then it all finally was right once I swapped in a correct type dual diaphragm booster for a 1966-70 B body. Mine feels right and stops as well as a newer car.
I’ve been helping a buddy with the blue Satellite seen above. He had an aftermarket booster that wasn’t working right (providing little boost) so I swapped in the same type booster I used on my car. Braking is excellent but like other power brake B body cars, there is a bit of a dead spot from the pedal at rest to where the pedal moves enough to feel the brakes responding. I accepted it as normal but the owner wants it to respond quicker.
The fluid level was fine:
Not full to the rim but not low enough to be an issue.
I pulled the MC forward and tried backing out the nub on the pushrod.
