Nacho-RT74
- 10:24 AM
- Oct 8, 2012
- Valencia, España
Damm! Allways forgett if is 18 or 16 LOL
Nothing wrong with it. Althought for correctness and if you care, should be gray
The only ground in the 72 tail light wiring harness is the one for the driver's side marker lamp.
I attached a wire to the side marker lamp ground and touched it to the driver's side tail light sockets. I only had to touch one to get both to light up. So that's progress.
I touched the wire to the passenger's side tail light sockets, and all I got was sparks. The bulbs didn't light. Why would that happen?
I think I'll have to replace one of the passenger side sockets. I can't get the bulb to seat right, it keeps popping out on one side.
My turn signals are acting like emergency flashers now - they both turn on either way I signal. The HVAC control lights flash as well, and my aftermarket tach flashes, and the instrument cluster lights flash. The IC lights that illuminate the cluster - the turn signal lights in the cluster aren't doing anything. I hope I haven't short-circuited something in the new turn signal switch.
