After market conversion engine mounts
Auggie56
12:02 PM
NW Ohio
There was no instruction sheet included. This mount was designed to allow a big block to use the small black k-member. Each mount is two pieces, the rubber one and the bracket, that bolts to the block. Question is, they both are identical, except one has a tube welded into the mounting holes. So which side does it go on?
Photos, mount brand would be helpful Auggie.
It would, but my computer from day one wouldn't download photos. And HP refused to fix.
No need to download. You can right click on image and hit copy then hit control V and it will paste where you want it...
Hy there.
I am new on this group and was wondering if you can tell me where I can buy this engine mount kit to fit a big block on the small block K member
Thanks in advance
