How goes the battle
The studs and nuts hold the bottom leg of the fender the large washer screws are for the dust shield rear of fender.I got the front fenders bolted back on. In my bag labeled "fender hardware" was some hardware that I don't remember where it goes. I have a picture attached ... any help/guidance would be greatly appreciated.
Wow still working on this car!! I would put the 3m bedding along the bottom and halfway up the sides on the metal fence then put bedding in the gasket mount on window and install with the rope method. The service manual has the instructions you can download on my Mopar site.It's been a long *** time since I posted anything and I need some advise. The wife is fed up with the rear window being along side the house and wants it installed. I'm at a point where I can put it in the car but it's been a long time since I've done one.
I know I need to get at least the rear of the headliner in place and probably need to make sure all the trim clips are installed correctly. I'm planning to use the rope method but can't remember if I need to use a bedding compound in the gasket or try and squirt in RTV once it installed. Any advise / suggestions would be greatly appreciated. Thanks.
Thanks Mark ... that helps me enormously!This is a single line distribution block on my 62. Hope it helps or is similar.
