65PlymSatellite
- 12:26 AM
- Jun 11, 2018
- Inland Empire, CA USA
Hello all, was hoping someone had run into the same issue as me, or can help diagnose. My 65 satellite with 273 and points distributor keeps burning up coils. It starts stumbling and sounds like it wants to die out when driving at normal temp. I replaced the coil, ballast resistor, and voltage regulator thinking it was one of those. When running at idle, I found that the positive side of the coil reads 14v. I drove around the block, less than 2 miles, and when I came back the coil was so hot I couldn’t keep my hand on it more than 3-4 seconds. It burned up an MSD blaster and I got a Napa replacement, and it gets just as hot. New and old ballast read about same voltage on input and output, as I tested voltage with key on with both.
Anybody run into this issue?
