- 2:39 PM
- Apr 13, 2012
- Granite Bay CA
The simple difference of using the “Classic Auto Air” evaporator matters significantly. Some, maybe most of theirs have the lines already on them and long enough to stick through the firewall. This Vintage Air Unit does not. The Vintage Air units have just male fittings attached directly to the EVAP unit requiring the installer to determine how to plumb it. Again, this can be good and bad. It allows a customer the option of running the lines through the wheel well if you don’t want to go through the firewall. Personally, I’m not fond of the added difficulty. This is where I find myself....at a bit of a stand still. Mounting the 4 port manifold on the engine side looks good and is much simpler for the engine side of the installation but really crowds the area inside where the EVAP is. It is doable but the Classic Auto setup was so much simpler.
