- 4:01 PM
- Apr 23, 2018
- Nanaimo B.C. Canada
I would stay away from any of the knockoffs, they are inexpensive for a reason.
Just got a good look at it, it's a 4200S. They were used '64 to '67 on 383's.
check the mounting pattern on that 67 intake. Chances are it is the smaller pattern which MIGHT make the Holley swap a bit more challenging. The AVS 2 works well, but the Holley/ATM/Quick Fuel carbs are much easier to tune.Is the Edelbrock 1406 electric choke a good carb for a stock 1967 383? The reviews are mixed.
This might be a stupid question, but can anyone tell me what carb came on the car from the factory?
I am leaning towards the Edelbrock 1406. I have noticed that Edelbrock sells this carb for around $428.00. Amazon sells this same carb for $205.00. Is there a difference? There is no mention that the Amazon one is a remanufacture.
thanks in advance
thanks in advance
Excellent point on the bolt pattern.check the mounting pattern on that 67 intake. Chances are it is the smaller pattern which MIGHT make the Holley swap a bit more challenging. The AVS 2 works well, but the Holley/ATM/Quick Fuel carbs are much easier to tune.
Get yourself the Edelbrock 650 AVS2 I have one on my mild built 440 and I talked two of my buddies into buying them and one is a 69 RR 383 and the other is a 71 Cuda 440 and they as myself love them. So easy to tune and the light to light acceleration in incredible.Is the Edelbrock 1406 electric choke a good carb for a stock 1967 383? The reviews are mixed.
thanks in advance
Asking about carburetors always gets a TON of different responses. Here are the key issues to minimize the number of "adapters" & "modifications" you have to do and end up with a good result:Is the Edelbrock 1406 electric choke a good carb for a stock 1967 383? The reviews are mixed.
thanks in advance
We run in both Stock Eliminator and Nostalgia Super Stock with a 383. I have run the stock (reworked, of course) AFB which is a tad less than 600 CFM with pretty decent success. We popped an 800 CFM AVS II (obviously not legal except for in Nostalgia) on and the car responded very well, posting better MPH. Since an engine is simply an air pump, it will use only what it wants to use - I would think the 750 AVS II would be a very sound choice and allow you room to do some future mods to the engine.check the mounting pattern on that 67 intake. Chances are it is the smaller pattern which MIGHT make the Holley swap a bit more challenging. The AVS 2 works well, but the Holley/ATM/Quick Fuel carbs are much easier to tune.
By the way, I have TWO spare period correct AFB's (choke removed, but start easily even when cold) if you might be interested.We run in both Stock Eliminator and Nostalgia Super Stock with a 383. I have run the stock (reworked, of course) AFB which is a tad less than 600 CFM with pretty decent success. We popped an 800 CFM AVS II (obviously not legal except for in Nostalgia) on and the car responded very well, posting better MPH. Since an engine is simply an air pump, it will use only what it wants to use - I would think the 750 AVS II would be a very sound choice and allow you room to do some future mods to the engine.
