frank vergnetti
New Member
With the 390-45-15 does it fit under the stock wheel well without any modifications to the front of the wheel well or the quarter panel And with the rear in the stock location? What rim are you using as far as width and the backspace and offset? Any help appreciated as I’m getting ready to start my project and it would be great to know before I start thanksI had 15x10 4 7/8 BS, with 325 50 15 MT Drag Radial, rolled outer wheel well, only rubbed on the hump that in made into the outer well when hitting a large bump, caused no damage or marks on the tire, also when turning into my sharp,steep drive way it would just touch the inner wheel house, put a rear sway bar on it & that cured that, now have 390 45 15 M&H , only hits on a large bump, still NO tire damage, this is the 325 50 15 , the bottom is the 390 .View attachment 1230627
