- 4:15 AM
- Apr 13, 2012
- Granite Bay CA
I have toyed with the idea of buying a clean Fifth Avenue but there is no way I'd buy one and try to make it emissions compliant for this state.
I wonder if you could swap in a Magnum 5.2 or 5.9 with the original EFI, converters and all emission equipment and somehow be compliant? It used to be that you could install a newer engine but you had to implement all the OEM emission equipment to result in equal or fewer emission readings than original.As far as the car goes quite honestly those cars ran like ****.. I spent two years doing drivability on them & hated it... Customers hated them... People who had owned Dodges for years bought those turds and I heard plenty of them saying they would never buy a Dodge again...
Leaving Dodge & going to Ford was the best thing ever... Ford built a few turds with VV carbs... But with a few adjustments you could make those run pretty good... The Dodges? Take that **** off & use a normal Distributor & carb... But that isn't legal... And here in California you can't get around it...
and so they traded them in for an Imperial with fuel injection.plenty of them saying they would never buy a Dodge again
I knew of a Mopar dealership mechanic that said he made a special test harness for the "Lean Burn" computers. One end had the mating connector for the computer and the other end had a household 110V plug.When I was doing drivability work at the local dodge dealer in 82-84 they had different names but those two plugs on the aircleaner all plugged into the same big scope style tester , they all had similar problems and they all sucked... Honestly I'm amazed there was still one running recently enough to get to the Rocklin PnP.... Probably dead in a garage for the past twenty plus years.... Cause they surely can't pass a California smog test...
We had a guy at the GM dealer do the same. He would spark circuit boards to short them out and then mark them so he didn't get them back.I knew of a Mopar dealership mechanic that said he made a special test harness for the "Lean Burn" computers. One end had the mating connector for the computer and the other end had a household 110V plug.
That was the only way they could get a warranty replacement computer for the customer.
From 2.45 to 2.76 isn't a big change, but multiple it by the axle ratio and it becomes a somewhat big deal...I wish I had a set of 8 1/4" axle 3.55 gears. That axle would fit great in most A body cars once the spring perches are relocated. The 2.45 gear is only good for a car with the low gear set transmission. This car may have that. In 1995-96, I pulled a 904 type trans from a junkyard car and didn't know at the time it was a low gear version with a lock-up converter. I wore it out and ended up replacing it a few years later and the car felt less peppy in the lower speeds. I found out that the latest transmission was the standard 904 and the first replacement was that lower geared one. I think they had something like a 2.75 1st gear instead of the 2.45 1st gear. It isn't much but it sure seemed to give the car more punch out of the hole.
Looks like the wheels are already gone. Some of those Cordoba and Mirada cars had nice looking wheels. Do the yards quickly recycle them (steel or aluminum) for cash, or are these wheels in demand by car owners?I hope someone that is looking for this stuff gets to the car before they pull and crush it.
Careful people might think you are referring to some country!!.Nothing like that here yet. But give them time. I think we will bypass that and jump right to a combustion engine tax. If those Castro followers get their way.
