My wife’s 2011 Ford Fiesta ABS, traction control, check engine lights all came on, plus no speedometer. I took it to auto parts store, where they diagnosed it to be a possible wheel speed sensor. So I took it to a local shop, they had it for about 45 minutes and they said they couldn’t fix it, needed to go to the Ford dealer (no charge so far). Ford dealer charges $175 just to look at the car. So after they look at it, they say it needs two wheel sensors, cost is about $700. Ford says that will fix the problem, so I say go ahead. A while later they call and tell me that after test drive, the lights came back on and the car needs a new ABS module, the bill will be about $1500. So I ask if this will solve the problem, woman says yes it will, so go ahead.
  A while later, she calls me and says Ford no longer make the part and they can’t locate another and they don’t install used parts. Ok, so I’m coming to get the car, btw what’s the bill? $1500. I tell her I’m coming to get the car and she can expect trouble, because I’m not paying $1500. She tells me wait, she will call me back. She calls me back a bit later and tells me that she met with management and they agreed to knock bill down to 700.
  So nobody wants to work on the car, so I decide to work on it myself, while sitting on my mobility scooter, fun. I found a place in Georgia that claims to be able to repair the module and keep the data from the car in place, so it would just be plug and play after the repair. Great, bad thing is two of the torx screws are unreachable, up against the shock tower. I had to take the whole pump assembly out. I send it out and pay extra for a rush order. The place gets the part, open it up and they text me that it is unrepairable . They send it back, no charge except the extra paid for the rush.
  So I decided to take a chance on a used module. I get it put in, bleed the lines and I happened to find someone that came out to program the unit. It appears to be working now, knock on wood. Oh, I forgot to mention, the dealership woman said they would be happy to have my car appraised for getting a new car!
