After a long drive, car dead in driveway — No crank, no start, and checked battery cables. This happened a few months ago and checked connections with a test light and multimeter. I got frustrated and replaced ECU and car fired up and was fine for three months.
So tried the usual suspects again — I can jumper starter relay and car cranks. But I get no signal from yellow wire when cranking. I also grounded safety switch lug to rule that out.
So, replaced ECU with a spare rehenberg blue box and still nothing.
Am I at replace ignition switch status or what else can I check before I open up the column?
I do get the buzzer going off when key is in ignition cylinder.
Thanks and any help is welcomed!
