Absolutely. Full throttle and keep it there and I bet there is some travel left at the transmission.How much adjustment is left?
How much difference is there in the location of the old carb mounting point and the new?
Again- WAY better to have kickdown on too early, than have no pressure in the trans.
Mounting point differs 1cm.How much adjustment is left?
It is kicking down but with a loooong delay when you really force it.'nuther kinda simple question-
Have you driven it? IE is it actually kicking down?
You could always put the old carb back on and see if it operates properly.
If it doesn't, that suggests something else happened.
Good point, the lever was not changed but the TQ has longer travel than the SD.Jonas,
What are experiencing is 'ratio creep' [ for want of a better term ].
You change carbs [ TQ looks great, like King-Kong ]. You adjust the lever for best upshift. Now no lick down. However one carb may need less [ or more ] throttle movement to achieve the desired shift speed; also, the distance from the carb primary shaft to the cable pin can differ between brands.
So you have these variables in the KD lever system that affects shift points. You may have to get different levers, drill new holes etc to get it right.
Thanks for the info and I do have a spring pulling the arm forward.While I'm a complete novice
on the workings of a 727,
I had the exact same
instance occur on a brand
new '76 727HP rebuild.
I run a Winters Sidewinder
cable shifter.
The trans would not kick
down no matter the cable
adjustment, no matter the
lever length. (Got one with
3 different holes drilled in it)
I finally reached my wits end
and drove it to an old timer
who cut his teeth on Mopar.
This may not be your case,
but as far as I could grasp
his explanation, cables do
not have the strength to
push the lever far enough
forward.
He cut a medium strength
spring to length that pulls
the lever to full forward.
There's even a location on
the trans case to attach it.
I've got passing gear that
scares me sometimes. Oh,
what a feeling!
Not to familiar with yourThanks for the info and I do have a spring pulling the arm
What do you mean?The OP has a 2 barrel throttle bracket and kickdown linkage with a 4 barrel.
Fix that issue and adjust properly, and I'd bet the problem goes away.
...unless he's already burned up the band/clutches.
What do you mean?
The throttle bracket is custom made and pulls the full length of the carbs throttle travel.
The kickdown linkage is adjusted correctly for when the gears should fall in and there is no slippage.
any chance you can post a few photos of this? I'm surprised a spring would work better than a cable. Both stretch a bit don't they?While I'm a complete novice
cable shifter.
forward.
what a feeling!
I'm no expert, but shouldn't your return springs be connected to the lower hole in front of the cable attachment shown in your photo? Not that this is contributing to your issue. That's the same cable I have on my car. Let's see a photo of your cable clamp. Lock it in and use a blue or purple sharpie to mark it on the the clamp so you can see if it's slipping when you push the accelerator. That thing needs to be pulled back hard towards the firewall to engage the spring (not to WOT) then lock it in good.Mounting point differs 1cm.
I checked again and when carb is fully open then the KD is bottomed out.
(Also checked with pedal floored.)
Return springs are connected at the throttle cable pin as they should be.I'm no expert, but shouldn't your return springs be connected to the lower hole in front of the cable attachment shown in your photo? Not that this is contributing to your issue. That's the same cable I have on my car. Let's see a photo of your cable clamp. Lock it in and use a blue or purple sharpie to mark it on the the clamp so you can see if it's slipping when you push the accelerator. That thing needs to be pulled back hard towards the firewall to engage the spring (not to WOT) then lock it in good.
great photos, thanks. The bottom cable is the one I'm talking about moving back more, not the top one. That's my one gripe with this Bouchillon setup - I wish each cable could be locked down independently.Return springs are connected at the throttle cable pin as they should be.
Kick down wire is clamped down hard and was marked with a black sharpie.
Interesting that you had to engage into the pressure a bit further than me.
When my carb is at idle the kickdown just hits the start of the pressure.
