Charlie Brown
I have the following Lunati cam in my 426 w in my 64 Dodge. The specs are as follows, as taken from their web site -
Hydraulic Flat Tappet. This high performance street cam likes 2400 RPM stall, 800 CFM carb, dual plane intake and headers. Makes un- equaled power to 6200 RPM with proper valve springs.; Advertised Duration (Int/Exh): 268/276; Duration @ .050 (Int/Exh): 226/234; Gross Valve Lift (Int/Exh): .494/.513; LSA/ICL: 110/106; Valve Lash (Int/Exh): Hyd/Hyd; RPM Range: 1800-6200
My question(s) is the correlation between the LSA and ICL combined with the advertised duration.
What kind of vacuum at 800 idle speed should I expect?
What is the significance of the split LSA?
What is the significance of the split ICL?
I'm having some minor idle in gear quality and before I get into other areas (carb, ignition, etc), I'd like to know if what I'm experiencing is cam spec. related.
Is this cam capable of getting 14 inches of vacuum at idle in gear?
Thanks in advance to all the cam gurus.
