TorRed
- 5:06 AM
- Dec 12, 2023
- The Villages, Florida
I've been gathering parts with the intention of stroking my 383, first for 489ci then stepped back to a 432ci stroker, but now I'm rethinking stroking it at all. It's mainly going to be built for local car shows with the occasional blast down the road, I might take it to the drag strip once or twice to figure out how fast it really is but that's probably it. I've been looking at just pistons and narrowed it down to either ICON or Diamond at 9.6 to 10.4 compression with my 80cc heads. So here's a list of what parts I already have which is most of them and just curious how the folks here would finish the build:
Carbs: Holley sixpack on Mopar 383 intake. Backup plan if the sixpack doesn't play nice would to be either a Holley Street Dominator or a Ede DP4B with the Holley Stealth Fuel Injection.
Heads: 440Source CNC'd Stealth Heads
Pistons: Looking at Icon and Diamond sets. Most are too low compression with my 80cc heads, could go custom if I had to. Could use recommendations here.
Connecting Rods: Can I get away with stock rods with ARP bolts? Otherwise, need recommendations here.
COMP Cams 1621-16 - COMP Cams Pro Magnum Shaft Mount Roller Rocker Arms
Cam: Lunati Roller Cam - Retro-Fit Hydraulic Roller. High performance street cam. Likes upgraded intake, carb and exhaust. Needs 2800 RPM stall converter in most cases. Requires 9.5:1 compression for maximum performance. ;Advertised Duration (Int/Exh): 282/290 ;Duration @ .050 (Int/Exh): 231/239 ;Gross Valve Lift (Int/Exh): .535/.550 ;LSA/ICL: 110/106 ;Valve Lash (Int/Exh): Hyd/Hyd ;RPM Range: 2200-6200
ARP 545-9801 - ARP Engine Bolt Kits
Dougs 1 3/4 Inch Headers
Dynomax 2.5" Ultraflow Mufflers
727 Auto with Turbo Action Cheetah Valve Body, FTI 3000 RPM converter, Gear Vendors .78 Overdrive. Could use good 727 rebuild kits recommendations.
8 3/4 with Tru Trac Posi, Dr Diff center section, 4.10 gears, HD everything else including axles.
So this car still has its original drivetrain in it, which has me thinking I don't want to go too far with the motor and risk creating new openings in the block! And I'm not married to anything above that just does not go with the rest of the build because again, most of these parts were purchased when the plan was a larger stroker higher HP build.
Thanks in advance,
Jim
Thanks in advance,
Jim
