- 10:27 AM
- Apr 13, 2012
- Granite Bay CA
In 2001, I built a 440 for my Charger and did my first big block swap. The car had a 318 so this was a big step for me.
I’d already read the tech articles in the Mopar magazines and wanted electronic ignition. I installed a complete kit from Summit Racing…Mopar Performance distributor, orange box ECM/ECU, ballast resistor and the wire plug for the spark box. Installation was easy. The car ran great but had a habit of sometimes suddenly misfiring. The reluctor air gap would go from the .008 to as much as .020 and would misfire under load. The advance curve was stupid long too. If I had timing set to 10 degrees BTDC, the total came in 38 degrees and the car knocked under full throttle. If I backed it down to 4-5 degrees BTDC, it wouldn’t knock but was sluggish to accelerate. It was then that I learned about distributor tuning. I had to shorten the range of the advance. Through a series of mistakes, I did stumble upon some help and was able to adjust the guts to limit the range to 14-15 degrees. For years now I’ve either had initial at 17 and a total around 31 or 19 and around 33.
This MP distributor though… on the outside it looks stock but inside it is a scaled down aftermarket design with small, light weights and springs. For years, Rick Ehrenberg has criticized the design, saying the design sucks and the light weights result in unstable timing and spark scatter. Mopar Performance stopped selling these electronic conversion kits a few years ago but a few others have stepped up to fill the void for those that wanted electronic ignition but didn’t want the huge MSD box or didn’t want to go the Pertronix route.
Not long ago, Ehrenberg began selling ignition stuff through eBay. Maybe a year or so ago, a guy on this forum advertised a kit he got from the Rick store. He didn’t use it since he decided to use a later Hemi. I bought the kit for a good price and just stowed it.
Last night at our monthly Mopar club meeting, a member put out this for the raffle:
This is the same model as the one I bought awhile back. The guy gave it up because he found that if you invert it like this….
The shaft will spin but sometimes stops and won’t spin unless you twist it harder. Something is making contact inside. It doesn’t do this when standing up normally. We told the club guy that unless he drives his car upside down he would be fine. He contacted Rick E and the man just sent him another and said to just keep the “bad” one.
I don’t think it is terminal… I’m going to take it apart and see where it is making contact. The reluctor and pickup are not touching at any of the 8 points. It is below the “breaker plate”.
