Fuel Smell
41indian
11:14 PM
Newark,Ohio 43055
1974 Charger SE.
Hi all, I have replaced every hose, seal, grommet clamp and no longer see any leaks but the garage smells like fuel every time I open the door and when I take it to work when I get off you can smell the fumes in the car.
The sender has one outlet and there is a vent hose on top of the tank.
When I remove the gas cap it really sucks in the air.
I don’t know how the vent line runs, maybe it’s blocked.
Modern fuels basically boil at operating temperatures so a lot of evaporation takes place when you shut off the engine and heat soak occurs. Is the evaporative emissions system removed from your car? A ‘74 should have a hose from the bowl vent to a canister in stock configuration.
Agree, is the charcoal canister still hook up?
Mine does Not have that system or even a place for it to be installed. I think your correct from going through my old memory banks a black 4 or 5 inch diameter cylinder with braided hoses. Yep, mine doesn’t have it. The fuel tank itself pressurizes when I run it, I would think it should not do that if vented
Do you have a FSM ? Is your ECS intact, connected, and functional ?
Factory Service Manual
How is your tank vented? If it’s building pressure the vent is plugged or non existent.
I just bought it at Christmas time, I’ve done a lot of cosmetic work on it and didn’t start driving it till about 4weeks ago. That’s win I found that all the fuel tank rubber was junk. I pretty sure that all the leaks are fixed because of the positive pressure it gets.
I’ll get under it again and see if the vent is plugged
It’s a 1974, I don’t think “Electronic Stability Control” or “Functional Safety Management “ was even a glimmer in Walter Ps mind then.
ECS = Electronic Stability Control ?
It's no big deal to vent your
tank and get rid of fuel vapor
odors.
You're not tied to locating
parts that are more than
50 years old and sometimes
non-existant.
In your case, I suspect a
plugged vent hose.
This pic is on a custom build
that utilizes a Corvette brake
booster charcoal filter.
$10.00 at your local parts
store plus a bug screen
typically used on a boat.
There are zero gas fumes
where this truck is parked
indoors.
Shown to the right of the bed
support.
odors.
non-existant.
plugged vent hose.
indoors.
support.
I like it, Thanks
I like it, Thanks
