Like someone else said, every engine is different. My 451 low deck B motor with flat top pistons 015" below deck, Edelbrock Performer RPM heads with .037" Cometic gaskets (any thicker and I'd lose quench) and Lunati Voodoo 60302 mild cam (475 lift, 220/226 @ .050, 112 LSA) is 10.1:1 compression. The most total timing i can run without detonation is 32 degrees. I selected my pistons before my cam and should have done the opposite so I could be down around 9.6:1 and have less worries and run more timing. I have my initial set at 15 and am running a Firecore distributor. So 15 initial and 17 mechanical locked in with the adjustable slots gives 32 total. I'm running the medium blue firecore springs and I'm all in on total timing by 2500 rpm. But guess what? It runs well on the street and has consistently run high 12's in the 1/4 with a best of 12.80 @ 108 mph. So whatever works.
I do not have vacuum advance hooked up. I've tried to run it with the advance rate dialed all the way back, but it pings. So I need to open it up and wrap a wire stop to limit the amount of vacuum advance and then I can hook that up and have better off throttle performance (just need to get around to it). Of course fuel octane matters too. Here in California the normal high octane is only 91. Two stations within an hour of me sell 110 octane, but it's super expensive.
