Anyone ever run or cut their own bearings to make them narrower? It used to be a racing deal....a bit narrower is supposed to free up some friction. I've never seen dyno results from doing that though.
There's supposed to be a tab on the back side of the bearings that match up with the rod and cap.....that places the bearings in the right position. Is that what you are asking? Some say it's an anti rotation deal to keep the bearings from spinning in the rod but if things ain't right, they will spin anyways.
He's referring to the half circle of missing metal... It was designed as a oil squirter to spray oil in the direction of the cam & lifters... Bearing manufacturers eliminated them many years ago... They claim they were ineffective & lead to lower oil pressure... I say any extra oil on the cam/lifters is a good thing.. But then again extra oil pressure isn't a bad thing either... I've built engines with both types of bearings & haven't had any failures in either configuration...There's supposed to be a tab on the back side of the bearings that match up with the rod and cap.....that places the bearings in the right position. Is that what you are asking? Some say it's an anti rotation deal to keep the bearings from spinning in the rod but if things ain't right, they will spin anyways.
Those squirt holes do NOT oil the cam, or the rods...well maybe a little mist. The way I've always understood it, their for providing a little oil spray, for the cylinder walls, piston skirts, and piston rings. It sure don't come from oil splash!!
Anyway...done biting my lip...
